nemáte zkušenosti s tímto výrobkem? Děkuji za každé info. Thule
https://www.wish....28de95d3d6
SWM 9601G 7in Bluetooth Car Stereo MP5 GPS FM/AM Radio with Map Card+ Camera
2 220 KčCZK
Specifications:
Model: 9601G
Type: MP5 player
System: wince
Decoder chip: C500
Screen size: 7 inches
Screen resolution: 800 x 480
Panel size: 178mm x 58mm/7.01 x 2.28"
Box size: 210mm x 239mm x 93mm/8.27 x 9.10 x 3.66"
Host depth: 160mm/6.30"
Whole machine net weight: 1800g
Hose net weight: 1526g
Mobile phone connection: support Android phones
GPS navigation: yes
Radio band: FM single band
Radio chip: QN8035
Language: English, Chinese, Russian, French, Spanish
Dual screen split display: not supported
Reverse video input: support
Reverse detection method: buttcock line detection
Brake prompt: yes
Steering wheel control: yes
Bluetooth: support
Amplifier chip: TDA7388
Radio frequency: 87.5M-108MHz
External memory card slot: mini TF card
GPS slot: TF navigation card
Remote control: 21 keys remote control
USB port: support USB 2.0
Reset button: NO
Mic: yes
RCA video terminal: 2-way video output, 1-way reversing input, 2-way audio output, 1-way video input
Front aux audio input: yes
Volume knob: yes
Supported audio formats: MP3/WMA/WAV/OGG/FLAC/APE
Supported video Formats: RM/RMVB/MP4/FLV/MKV/3GP/AVI/ASF/SWFMP1/MP2
Supported image formats: JPG
Features:
1. 7" High Digital screen 800*480,Touch screen
3. Support the Audio playback format of MP3/WMA/WAV/FLAC/APE etc
4. Support the Video playback format of RM/RMVB/MP4/FLV/MKV/3GP/AVI/ASF/SWFMP1/MP2 etc
5. With Front USB2.0 port and TF card slot
6. BT function,free hand call and BT music
7. MOSFET Amplifier: 50Watts x 4 max power output
8. AM/FM stereo Radio
9. Full IR remote control
10. Power-off with auto-memory store function under radio or TF/USB mode
11. Clock function
12. Mute function
13. Bass+ Treble, L+R channel stabilizer
14. Front AUX in function
15. ONE way Video output function
16. Two RCA audio output function
17. One way video input function
18. 2RCA audio input function
19. Rear View Camera input function
20. Steering wheel control function
21. Sub-woofer output function
23. Mirror link
24. Front and rear microphone function(rear need extra purchase microphone)
25. Installation size: 178 x 50 x 168mm/7.01 x 1.97 x 6.61"
Notes:
1. The display does not come out automatically. You need to manually push or pull it to prolong it service life.
2. When using navigation function, you need to first locate, search for stars, and import maps and it can work normally.
3. As long as the car's installation size matches the machine, it can be installed and used.
4. When installing the machine, be sure to connect the wire correctly. If it does not power on the machine, please connect the red line and yellow wire to the 12V power supply positive pole, the black wire to the power supply negative pole, and try to see if the machine can normally power on. If it can not be normally powered on, then it may be wiring problems, you can seek our help.
Included:
1 x MP5
1 x Remote Control
1 x Buttcock Line
1 x GPS
1 x Map Card
1 x Rear View Camera
1 x User Manual
